rtbcomp
Moderator
- Sheffield UK
trailer sockets are great as you can't pull the plug out by accident.......
On the other hand if you trip over the cable you could pull it out of the plug!
but there would be nothing worse than crawling under a muddy wet landy to fix it (regularly) and just as you move the torch to light up the part that needs hammer time the lights go out!
Batt was pretty flat so maybe get it running properly tonight, or tomorrow.Can you put a tee piece into the oil pressure switch mounting? I did that with an RR pressure guage.Found there's no place for the oil temp sender to go, so hopefully I can sort out a bung to weld onto the sump.
Carb and/or timing needs bit of tweakage but all good so far.
). The springs will get painted outside and on edge, and motorbike chain oil forced twixt the leaves like I did with the back ones. Bit of Jenolite here & there, red oxide, 2k black for the rest of it, same as out back.
Love it. Big Kids Meccano
Rebuilt mine 3 yrs ago. disappeared in the front garden, was reborn in the back, with not a nut or bolt untouched over 10 months.
