That's okayHi, Kim. Sorry, it was not my intention to nag or confuse you.You stick to what you're comfortable with.
Again, well done.
Colin
doubt if you could do the same module 5 times though
What I found odd was Mrs Robo (PCV driver) can do the same module twice over the 5 years and it counts as 2 modules towards the CPCdoubt if you could do the same module 5 times though
Which side inside or outside ?Would you have an pictures of the top of the bulkhead where the windscreen frame meets? I have to repair mine and some pictures would help. Mine has rusted through on the corner by the mirror/below the windscreen frame
Good luck with the work.
Here you goOutside, looking at front side (as if you are standing at the front of the car looking towards the landy)
Kim
. But like you say they can be waxoyled.
I was going to zinc plate, then two coats of spray primer then maybe three coats of nato green and on the underside I was going to underseal it with a durable black paint which I've not worked out yetWell if you leave a bzp bolt and a galvanised bolt outside the , zinc plated one will start to rust first . I presume your bulkhead will be zinc sprayed ? In which case any voids won't be covered. But like you say they can be waxoyled.
If it's blasted then zinc sprayed then painted I think it will be a good job , it's either that or you make a frame to hold everything in shape then hot dip galv the lot ??
Decisions decisions
Cheers MIke
Already gone now, I'll make some up easy enoughCan't add much about zinc plating vs galving but companies such as ash tree seem to be churning out galv'd bulkheads so it must be doable without it warping? But in terms of the waxoil after doing a bit of reading it doesn't sound like a great idea on metal that's already rusting because you're then just covering over it and you can still get problems, happy to be proven wrong about that it's just what I read.
Also on a side note if those pedal box gaskets are in reasonable shape keep them because last time I was looking for some I seem to remember the cheapest I could find was some ridiculous price like 20 or 30 quid
could always use gasket paper and sealant I guess or I'll source some blank gasket stuff like oemI used an old innertube which seemed to work well as it has a bit more thickness to itAlready gone now, I'll make some up easy enoughcould always use gasket paper and sealant I guess or I'll source some blank gasket stuff like oem
