Gareth_16V
- Michigan, USA
Not sure if you've already tried, but bleed at the master as well if you've got the access. I'm guessing the master outlet is the highest point in the system so air will be trapped.
Had the same on a motorcycle hydraulic clutch system which was the same. Finish off with a bleed of the master and all was well.
