could if i had an m12 fitting caliper ...but then isnt that job much the same as clamping the rubber hosewhy not take the connection off the slave cyl , bung on an old brake caliper and bung a few pads in it to take up the gap ,,, bleed that in situ , then you have half the system bled and tested ,,, if it works bung the connection back on the slave cyl ,,, it really shouldnt cause this much grief , now it is causing grief start eliminating things .
ive thought about extending the rod (theres only one size slave avail for these ) and i even had the orig factory slave refurbished as i thought maybe theres some magic inside it lol , anyway always been shot down if i say about extending it , and how would i know when its just enough and im not riding the release bearing all day long? if i could be sure im not on the bearing id happily give it bashYears and years ago I had a mini which I had a problem with the clutch clearing, operating lever wasn't bent and worked fine when using a large pry bar on the lever, everything was bled fine. In the end I made an extendable rod for the slave cylinder to give extra movement to the rod.Is it possible the rod on the slave cylinder is too short or bore too big?
nope ,, as you can see whats going on with a caliper , and it has a bleed point , so you can bleed the top half of the system and be happy its working then its just a swap of cylinders . several posts ago I did mention taking the cylinder off the bell housing and putting a g clamp on it , so you could get the cyl in an orientation that would let gravity bleed it ,,, it is still an option .could if i had an m12 fitting caliper ...but then isnt that job much the same as clamping the rubber hose
and orientate it to let it self bleed ,,, it was mentioned four pages ago ,,, lolI'd be shoving a screwdriver in the hole, and seeing how much effort/travel it takes to move the fork.
You could also try bleeding it in situ, remove the slave from the gearbox, clamp the slave, then see if the pedal is firm.
think he said it was all brand new ,,, could be wrong thoughCrank thrust on its way out?
it does not have to be down hill ,,, thats part of the issue , it needs to bleed at the highest point . ie bleednipple above the cylinder , as long as its below the reservoir it will self bleed. Well see what happens when new bits arrive ,,,, I had a G60 and did 120k miles in it ,, great wee car.i cant orientate it so its all down hill....would it even gravity bleed with the coiled line?
ive given up until the new parts arrive anyway
few mins will tell you that you have flow or not ,,, if you can get the bleed nipple higher than the rest of the cylinder and the loops in the pipe it will bleed ,,, ideally self bleed , if not you will have to pump it , if you do need to pump the pedal you will have to clamp the rod in... or cut out a notch in a plank and use that as a clamp to stop the piston coming out ,,, I dont know if they have a circlip on the end of the slave cylinder or not ,,, so air on the side of caution ,,,, crack the bleed nipple before you take the cyl off , and only snug it up , then your not trying to wrestle with a tight nipple and a clamp and a bit of hose all at once .... i take it you have someone to pump the pedal for you , as its hard to do both bits on your own.is that what you would try first? crack the nipple and wait how long?
tempted to try the vac bleeder ...i dunno fed up with it really
ideally clamp it all the way in ,,,i can get the mrs to help if need be , just trying to be super carefull with the new bits
if i clamp it...push the rod all the way in ? or just clamping it anywhere will do? dont want to damage something forcing it too far
master has a bleeder on as well...where does that fit in with gravity bleed? do that first or let it all go out the slave?
I know a lot of that sounds very basic ,,, but sometimes basic is a great starting point.yeah cheers for the help , will report back
I mean does the pedal come back up far enough to allow the piston in the master cylinder to come all the way back out to it's stop? Usually that would mean a small amount of free play in the linkage before the pushrod starts moving the system.freeplay where ?
pedal with no master operates up and down with a over center spring , pings up pretty sharply
master rod is in the fully out position when the clutch is up
no free play on the clevis fitting the pedal...are you suggesting like a badly worn pedal where the pedal moves but takes an inch until it works the master? no thats not happening
