steveo3002
thats how the factory fitted the coil, ive looked it up on parts diagrams and asked other owners , i did have a plain flexi on it with no coil , was the sameThat curly steel pipe next the slave should be the other way up inlet (hose end) at the bottom, and the outlet (slave end) at the top. Then the air will come out.
You could try dismounting the slave from the gearbox, leaving it connected to the hydraulics. Then rig up something to hold and clamp the piston down at the nipple end, then bleed it with the nipple uppermost. That if you can get at it.
Also, more pressure, 30 to 35 psi, and open the nipple more.
