wouldnt matter ,, unless you were very unlucky as the fluid will be trapped between the two cyls , the master is only there to top it up ,,, if that was the case , unlikely still ,, bleed the master cyl bleed nipple ,,, again , two people and a hose and jar , watch fluid level and lock off nipple at the bottom on each stroke holding pedal down , then slowly letting pedal return .... occasionally put in a pressure bleed ,,,yeah dunno thought it was almost a dead cert that it was done now , the feed to the master is just push fit might have tweaked that and let air in
pump pedal three or four times ,,, hold pressure with foot on pedal ,,, just crack the nipple , when the pedal hits the floor , hold it there and shout down ,,,, person doing the bleeding tightens nipple , then shouts up ,,, person on pedal slowly lets pedal up , and shouts up ,,,, then still with nipples closed ,,, try pedal .
