Luggsey
- Devon
If it is its made super strong?I think it may be for filling bearings with grease
X 2 ,It looks like an automotive bushing tool but that brass threaded insert makes it way more engineered than any car bushing tool I've seen. Is that an oring on the plunger?
. And next weekend's task is to get rid of more junk, and there's plenty more to go, get the dive cylinders away for inspection then construct a welding bench in front of the up and over door:
It does'n matter how big or small the hands are if you cannot see the little blighters in the first place.Screws tightened in 5 pairs of glasses, and a screw that fell out of one pair refitted.
1.4mm diameter screws are all well and good but not when you have hands the size of Eric Olthwaites's shovel.
A pound to a pinch of S*** the next job/project will require exactly the piece of "junk" you've just ditched. Don't ask!!!Finally made a start on the "Big Clear Out" this weekend.
Onroot to the shops this morning I called at the tip with the van crammed to the gunnels with pure junk that I've been moving from one side of the mancave to the other for the past 3 years. Offcuts of crappy boards and timber, useless lengths of rusty steel, bits of old lifting gear and all manner of tat, gone! And the end result:
Space to move around and benches to work on. And next weekend's task is to get rid of more junk, and there's plenty more to go, get the dive cylinders away for inspection then construct a welding bench in front of the up and over door:
I'm sick to the back teeth of useless clutter so the time has come to get rid of it all, and the contents of the mancave, shed, greenhouse and my manroom will all be subjected to very close scrutiny which coincides nicely with a 3 year plan me and OH have instigated which will see us moving house and me giving up driving lorries by 2024 when I'll be 60.
As I've said before " come in hand even if you never use it "Found this at the local recycling yard a while back. Paid £5 for it.
Looks like a bearing press?
Cleaned up and rust removed today.
Anyone recognize the type?
Love to know its specific purpise?
I may use it one day.....
Appreciate the sentiment but none of it will be missed.A pound to a pinch of S*** the next job/project will require exactly the piece of "junk" you've just ditched. Don't ask!!!
examples being a dozen Pandrol clips
Some I am willing to help out. To allow others to be helped.Personally I think you should have had a forum 'drive by'.
Trundle past at 5mph and grab an armful on the way past!
Although I think a few members would have not been able to resist the urge to keep going round
At least the Vark would have been too far away!
so I saved the £4.99 on a new one and fixed it
The end fell off my paint poleso I saved the £4.99 on a new one and fixed it
and they said buying a lathe was a waste of money.......![]()
it really did shat itself,
Fingers crossed it’s simple then. I need to do the shifter arm seal too, that is dripping, so the oil pan needs to come off, so a new filter screen and gasket will go in.I had the autobox input shaft seal go on my 2.0S Capri a week after buying itit really did shat itself,
Not sure if it's the same box but was 3 speed
I only had to replace the seal and it was done without stripping it down
Don't know weather this helps or not.
