It fits my shed and accurate enough. Without the motor upgrade it was rubbish, but apart from that I think chinese 10" lathes all about the same. A good used Harrison would be better, this only makes sence with limited space.
Anyway the 14TR2 thread not perfect. I did not bottom out the insert as I thought I was past full depth, so I think it needs to go back in for another cut. The split nut is tight (on and off) normal way round. If I put it on split end first it is free spinning
Marker pen rubs off the root.
What’s a edge tailstock alignment bar?It came out perfectly, en16 is a lovely material.
Like you I don't mess about with the compound, straight in.
Bed. To be honest I never perfected it so it's about time.
Got an edge tailstock alignment bar for the tailstock.
I just turn a piece same diameter as tailstock barrel and clock across. Good way of measuring tailstock sled wear as well
How much!?!It's just a bar with centres and a ground diameter on each end.
https://www.edgetechnologyproducts.com/tailstock-alignment-bar/
 I'm pretty sure I've seen DoubleBoost do it with a length of 10mm stud with big washers on each end.
What stock did you use? I haven’t got my mill working so can make a hex.
