Hope you're going to tidy the wiring up?, the terminals are carrying the weight of the cables at presentif the VFD doesn't have a gland plate in the bottom, mount a small adaptable box directly underneath.
Use the correct glands so the braiding is earthed.
I have a tom senior with a similar leak where the drive shaft enters the table, does anyone have suggestions how to fix that??I've only done odds and sods to this recently, nearly finished, just need to take the bed off again to see if I can fix the leak from the universal joint where the power feed shaft meets the carriage, turn up a better bush for the motor pulley, finish off the grills for the suds drain then adjust everything up and grease/oil the various bit.
I'm going to move my morticing machine further down the workshop and place the in its place, I rarely use the morticer but I have a got a couple of jobs planned for it. I was keeping one side of the workshop for wood working and one for metal but the metal side of things seem to be taking over!
Here's the badge back on.
Cheers
Andy
Chicken head knob? It's not an insultits the type of knob used on old valve amps etc. a quid off fleabay, what do you think?
