Mated together and prepared the new drivetrain for posting into the 90 in place of the knackered original 19J engine & LT77 box with worn splines to transfer case. Its a refreshed 200tdi with new seals/cambelt etc, 19J bellhousing drilled and tapped with extra studs to match the 200tdi, unworn LT77 12J gearbox & a discovery transfer case that has slightly higher ratio lowering cruise rpm on long trips. I have a 12J low ratio transfer case that can go on if I decide I need the lower ratio to tow heavy things or the original 19j ratio transfer case for a middle ground, either of which should be a easy task to swap over in the car (famous last words...)
Lots of work to go, but extremely theraputic to be freeing up storage space.
but that's what she wanted. The offcuts of wood pile wins again.
