angellonewolf
- bristol england
on another point has the keyway sheared ive heard this can do these sort of problems even a bit out fires at the wrong time causes the hard starting amoung others
Nope, 52cc shouldnt need it, my chainsaws dont need to including the 72cc g372, which has one.150 psi is good. Is there no decompression button on it ?
Any way to slot the coil mount to adjust the timing?Nope, 52cc shouldnt need it, my chainsaws dont need to including the 72cc g372, which has one.
All the amazon reviews say the same thing, so its likely a designed feature of the timing perhaps a bit early?
If I flick the kill switch off and back on, you can hear it fire early and stop, not good.
I read, some have a variable coil that delays ignition below idle speed.
I know you can change timing by moving the keyway slot but how do you measure it in degrees?
My 254s have decompression buttons.Nope, 52cc shouldnt need it, my chainsaws dont need to including the 72cc g372, which has one.
I looked up the correct gap online.Any idea what gap I should be aiming for?
Had a play with my chinese combi engine today. First I ran it for a couple minutes, tho the tester box says 15, anyway the result was
Around 150psi. Thats with the tester suggested earlier in the thread - has a valve at engine end to keep the hose presssurised.
Is that acceptable for a new engine? It has not done any work yet, only a brief test of the tools, running time of under 20 minutes, so it is far from being ran in. The bore looks new and clean.
The problem with this engine is hard to start - you need to pull it hard. Less than a hard pull will suck the cord back in and hurt your arm, which shows its igniting early and sending the piston back in reverse - wont be fun up a ladder!
I'm told a fix for this is to enlarge the coil to flywheel gap. I measure it at ~0.35mm with feelers. I tried adjusting and at 0.45mm theres no difference.
Its not easy to do! Currently Im putting a feeler in the gap but the thicker feelers have a bit too much spring in them. I'll try 0.8mm tomorrow, perhaps I can find some suitable plastic.
Business card
It got it tore down. It's the main bearings are badly worn and causing issues. So yet another mis diagnosis! The original Stihl cylinder is like new. The piston could be re used but has one weird scratch on it. I'm almost certain someone jammed a screwdriver in there as nothing else could have caused it. I could sand it out but I think it's best get a new aftermarket piston for it.
Some additional clues for the crank bearing issue:
Anyway in terms of parts cost, this one will be a relatively cheap fix. They also installed brand new air filters and likely charged the guy for that and their mis diagnosis.
This saw is so clean it may end up staying in my collection I'll see.
I can't remember what model it is, the labels fallen off recently, I'm getting oil below the exhaust muffler.What saw is it?
Get the bar and cover off, rinse the oil tank with a bit of petrol, drain and wipe the outside dry with a rag.
Add a little petrol or light oil and hold it bar side down and if hose before oil pump is split you will see it peeing out.
It doesn't seem to be blocked, just leaking.
Is there a rubber pipe or does the oil pass through passages in the plastic moulding ?
I'll get photos tomorrow, thanks.Not sure about that vintage saw, but it should be easy to open up and check.
Start by removing the bar and chain and poke wire through, make sure the bar's oil feed is clear. Then there should be removable covers to inspect the oil pump and any associated plastic lines.
