I do exactly the same I have done for nearly 40 year's including 25 year's of HGV work. I remember when the first hgvs came out with M22 flat seat studs, everyone said " any lube on those and they will come loose" it never happenedwho on earth changes a stud unless its actually knackered though?
There are two reasons why wheel studs are damaged in the first place - 1. too much friction or corrosion causing galling; and 2. rough-ass tightening with too many ugga duggas.
This is why I always use copperease and torque to the manufacturers minimum torque. Will never damage anything, as that extra 20% fastener tension is well within the safety margin by design.
We've had this argument before several times on here, and each time there are people adamantly opposed to lubing wheel bolts - I understand the theories and there are pros and cons both ways. Ultimately I go with lube.
Oh Dear ... let me know which garage you play at & I'll put it on avoid in my sat nav.
You would of thought the clowns that market these would of included that one.
