Moved the drill press off of the bench top:
not much clearance by the time you lift the vice up and you put a drill bit in for metal to clear the bench top
Far too tidy
Sorted the pressure gauge & air intake, new oil, splodge of paint running sweet. Fits under the bench![]()
TBH I pretty much stripped it, then as well as the above, redid the wiring to the start cap, valves checked, some odd additions to the air intake set back to standard and a lot of polishing/cleaning.Nice work, looks like a completely different machine!![]()
Nice work.Original switch for my clarke pillar drill gave up the ghost years ago and couldn’t find one online so bought a generic one which was a bit too small.
so using this as an excuse to practise my welding skills i made an adaptor plate for it. first time welding with gas
the bolts in the plate arnt aligned as the original tapped holes in the drill itself were way out!
started with some CAD (cardboard aided design)
View attachment 297018View attachment 297019View attachment 297020View attachment 297021
can't complain, inherited it from my grandad, it's served me well! and good to know in case i need a new beltNice work.
But I have a spare.
They are good drills, the V bely is a 10mm wide belt at the top.
Far too tidyView attachment 296495
Can't have it any other way, I simply don't get enough time in the mancave to be anything else. Being away all week in the wagon means I have limited time for projects so I prefer to spend that time usefully rather than wasting it looking for tools or tripping over junk that's littering the floor. And in my opinion walking into a clean and tidy workshop is much more conducive to maximum efficiency and productivity.
We did it at gcse level CDT (craft design and technology as it was called in 1990) Also did mechanical and electrical engineering national diploma for 2 years after that, sadly never touched a lathe ever since, wouldn't know where to begin to use one now.Screwcutting is not difficult. You just need to understand what it is you're trying to achieve and the steps you go through to get there.
I felt the same as we were not allowed to do it at O level metal work. You had to wait until A level for that, which sadly I never did.
worrying amount of flakes too. Cleaned it out and added some Moly.
As I've just relocated the contents of our storage unit to the new garage, presently there's nowhere to put a workbench. Your photo here has given me the inspirationView attachment 296495
........................................ And in my opinion walking into a clean and tidy workshop is much more conducive to maximum efficiency and productivity.
Why didn't think of that.I recently put new 80w transmission oil back in mine. Is moly better?The new to me bandsaw has had some TLC.
Gear box had some goop in it that didn't look much like greaseworrying amount of flakes too. Cleaned it out and added some Moly.
I'm hoping that will slow down the demise of the gears..
Need to replace the blade as it has a dodgy part somewhere but still cuts![]()
Moly is better than nothing which is what it had in it!I recently put new 80w transmission oil back in mine. Is moly better?
