If I had legs like that I would have them amputatedThe last time I saw legs like that they was hanging out of the edge of a nest![]()
Before I headed home I made up a bracket to fit the digital scale to the tailstock. I then chucked up a bit of 30mm thick 4.25" dia aluminium and turned the OD to 100mm and bored out the inside to 58.42mm and parted off 20mm thick.
Then onto the Chiron for a bit of milling and I ended up with this collar.
Fitted it to the quill and it works great even though I bought the wrong orientation scale
I wonder how long it will be before the reading is / can be horizontally read rather than vertical on such digital scales ?Before I headed home I made up a bracket to fit the digital scale to the tailstock. I then chucked up a bit of 30mm thick 4.25" dia aluminium and turned the OD to 100mm and bored out the inside to 58.42mm and parted off 20mm thick.
They do have them, I just ordered the wrong one.I wonder how long it will be before the reading is / can be horizontally read rather than vertical on such digital scales ?
Or am I still living in the past ? .
Present for someone.
Been a few years since I last made one, I'm quite pleased with it.
I took a few pictures of the process, I'll write something up in a bit.Would be really nice if you could make a bit of a thread on how you made that. I am sure someone will be along in a second to one of the youtbe vids but I would be more interested in your approach. Very nice that.
I had some good results with silverflow 55 brazing with mapp recently so had another go at the er40 collet chuck. Well it sticks, took a bloody lot of heat and still was not quite hot enough to flow properly. Ive got some ideas, I might try reheating it tomorrow, but I think itll be good enough. Does mean I'll need to face and recut the taper.
Yes I got some in the taper so it will need to be recut, Im not sure about distortion, it wasnt a problem last time - I was still able to indicate with no significant runout on the taper or od.the whole thing would need to be remachined, you'll be amazed at how much distortion there will be from silver soldering/brazing
Better than galv in many cases
