Matchless
I started with nothing, still have most of it left
- Essex UK
Last day of welding, just a patch on the rear valance where the tow bar went through, and finish the o/s/r seat pan but I cannot open that door far enough at the moment,
area under n/s of rear seat, foam seat base holds water! cut back to semi solid metal, at least 0.4mm thick! now pots of grinding to do!
Note the nails, I welded them to the rear chassis rail before dropping the patch over, then use the claw hammer to pull the patch down, top tip?
area in front of the n/s/r wheel, you can see the new jacking point.
Patched up, going to be on grinder all day tomorrow!
Seat base half done,
I've seen your type on other builds, but most switch to the later 2 speed for ease of parts and reliability
