Carefully read the "Aluminium TIG basics" thread from Richard, it's great !
Well I realize a little bit late my miswriting (as you may see I'm not englich native ...), I was'nt able to edit my post anymore.Where would he find that?...
On a more serious note. Thicker Ally will make your life a bit easier but I agree with above, stick with the flat plate drill for now. Especially when learning Ally.
When your flat plate is 4 inches thick with perfect beads then move to joints.![]()
3. Basic current-------------------------I'm not sure on this !!!
6. Pulse frequency----------------------I'm not sure on this !!! I am thinking what Richard said "Frequency (again no link to pulse) its AC frequency and this allows you to set the amount of -------------------------------------------time fluctuation happens over a period of time and is usually set in Hz/sec"
7. Pulse duty----------------------------Works in conjunction with switch 14 !!! Nothing to do with button/dial 6. Pulse frequency.
Hi there Misterg,Go on then, I'll have a go (based on general knowledge, not direct experience of that machine):
The three settings above only have any meaning when switch 14 is set to pulse mode.
When 14 is set to pulse mode:
#6 controls the frequency with which the arc switches from low to high power. If you set this fully anticlockwise it will make the effect of the other controls more obvious.
#3 sets the "low" or background current between pulses (high current is set by #2).
#7 controls the proportion of time that the current is high or low: 10% is 10% high / 90% low; 50% is equal amounts of each & 90% is 90% high, 10% low
Any use?
Taken from a previous post if you don't wish to read through a long drawn out post you can use this simple guide settings below
Alu
These are very rough settings that I know work they don't cover all case scenarios but they will get you results and you can fine tune as your experience grows.
- Set machine to ac
- Set balance to 70% dc negative
- Current work around 40amps per 1 Mm of material thickness
- Frequency 80hz for butts, 120hz fillets and outside corners
- Gas argon 100% @ 6-8lpm
- Pre flow 1sec
- Post flow 6 seconds for 1mm and add 1 second for every mm after
- Arc length 1-2mm
- Torch angle 10 degrees from vertical lean away from your direction of travel.
- Tungsten white, blue, gold, grey, don't worry about which people prefer at this time.
