Trafimet should be a much better quality torch.I would love to shove the Trafimet torch on to see how it would perform on the Jasic but warranty is stopping me even though it works in exactly the same manner ie a blowback ignition.
The one I have fitted now is supposedly 0.01µm which I can believe when I looked up the priceI was looking at the Camozzi filters today that we’ve got at the plasma table.
There’s a 25 micron In the regulator, 1 micron then 0.1um.
Yes, top quality stuff and the sad thing is I can't use it even though I have loads of consumables. Maybe if I live another 5 years and the Jasic does too, then I will be able to try it outTrafimet should be a much better quality torch.
What’s to stop you running the torch? Is it not plug and play? Do you have to hack into the Jasic to run it?The one I have fitted now is supposedly 0.01µm which I can believe when I looked up the price
I would have to swap pins around but my big fear would be I forget, post a video and some Jasic person sees it and...What’s to stop you running the torch? Is it not plug and play? Do you have to hack into the Jasic to run it?
The Trafimet is also only 65 Amps rated but that would be an issue for the torch if I forgot to turn down the current or at least I would imagine it would only be the torch that would melt.
Need a water table nextThe Jasic is still performing very well and the fast pierce still makes me smile.
Cut up two sheets of 5mm Aluminium today, set the pierce to 0.5seconds and feedrate of 3000mm/min.
It is just a limit switch, got the idea from someone on the Mach3 forum, not sure if he had seen it somewhere or not, think he is on here as well. He used a normal micro switch with the metal lever but I had a Telemecanique limit switch spare so I used that.BTW what is that height probe you're using ?
