daedalusminos
- Norwich
For metric it is simple, just deduct the pitch from the diameter and it will be close enough for most threads.I do much of my work in the evening, often up to 10pm-midnight, have my diner after or I dont get much done. Problem it stops me doing noisey work like grinding, tho doesnt stop me swearing, when I found I had more to grind off. I use marker to check rubbing and there is none, and Ive got 2mm clearance to allow backing out
Anyway I now have it all set up for the M13x1.0 nut. I couldnt find a drill size but it seems 1mm pitch bores are 0.9mm less than the size, so Ive bored to 12.1mm.
I've never tried that, given that the insert is on top I assume you are running the spindle backwards, which theoretically I can't do but would probably be ok with for light passes.![]()
Locking nut. This was much quicker, tho was not a through bore like the last. I cut a 2mm wide relief at full depth to start, 1mm away from shoulder. I do like threading away from chuck!
Its an extractor of some kind ? ooo im slow tonight/this morningI also just made this tool. It featured a tapered thread (of no particular pitch or threadform). Happens to be left-hand too but that's not significant. I'll let you guess what it's used for. It has a 22mm hole though the middle
