What's the material? Is it specifically for casting patterns?That’s the last pattern done. Just need to flip it over and skim it to finished height on Monday
It's for a radius brake, I've a bit to go yet plenty to mess up yet, it will be adjustable for different diameter of tube, I plan to bolt them onto the sides of the table I made for welding on that now just gets filled with crapWhats it for?
Guy has an R&D flexible coupling on the prop shaft of his boat but it keeps failing so he is wanting to put a solid spacer in. There is not enough room to feed bolts in that would go right through so I made that up so it will use 12 shorter bolts instead of 6 longer ones.Looks good, hub or some kind rubber cush drive? Big for an AT? Boat?
