...struggled to find the thread details in my Zeus book...
well well well.............every day is a school day!..............I used my eyecrometer in the end. Cheers
They've messed up Whitworth and bsf/bsc/bsp on there though...
Just the naming, like that they've called bsf (British standard fine) Whitworth fine and bspt Whitworth pipe tapered, I know most bs threads are derived from Whitworth but I've never seen bspt referred to as a Whitworth thread.I have to ask please what you have seen that is incorrect as I could not see anything obvious on BSW and BSF (near the bottom of the page in green). They have the wrong imperial major dia. on BSPP (but correct metric major dia.). Also, I could not see BSC at all (normally denoted BSCy and 60 degree thread angle).
Just the naming... ...and I mean British standard coarse by BSC is this not the correct acronym?
Time to get those tools I linked to.Wrote out a nice message here but refreshed and deleted it bugger
Bit of playings on the training lathe not my own , trying to achieve a nice finish with the inserts and tool we had. First tried the manufacture recommended speeds and feeds however these where the quite fast and hard which did get a nice mirror shine off the cut however was a lot of grooves and deep lines chatter and stuff as not sure if these lathes 2hp and not very rigid can really handle that may have been some slop somewhere did try tightening gibs but not a huge help.
Then a mate recommended the complete opposite low feed and low speed thought hmm that seems like it'll work even less but worked quite well IMO , insert spec sheet shown and it was set at
80 then 180 RPM same finish
0.001 inch per rev / 0.03 mm per rev feed
Coolant flood
Only thing is with those speeds / feeds its a boring job lol sitting there waiting for it to travel across only good for final finishing dimension cuts but also works well for that as can tickle off a few thou easily and still produce a good finish rather than being stuck with needing to take a bigger DOC for proper carbide speeds / feeds
View attachment 319394View attachment 319393View attachment 319395
Camera makes the finish look worse I think picks up all the lines but really impressed with finish really smooth doesn't catch fingernail and can see reflections in it
View attachment 319397View attachment 319396
Yup those tips really need pushed on a ridgid powerful lathe to get a good finish I think , not sure how the YouTubers make it look so easy lolTime to get those tools I linked to.
Yesterday though I was just turning down a bar to act as a spacer. In a bit of a rush pushed the old Triumph a lot harder. Seriously deep cut could actually hear the lathe working. The swarf flying off was golden brown and smoking - best finish I have ever had with a cnmg or whatever they are called
For normal use though I prefer those sharp aluminium cutting tips.
If you don't have to jump out of the way now and again you're not trying @fizzyTime to get those tools I linked to.
You are right there only baby cuts in the past.If you don't have to jump out of the way now and again you're not trying @fizzy
