But if you looked now,you would have more Shekels for beer….
Oddly the wife's just come in to talk to me so I'm off to the garage.
@Johnnybravo@Onoff Any single phase 2800rpm 0,75-1hp motors in there, surplus to your needs?
That's a 2 pole motor. 4 pole are 1450rpm.
I got an , Advent calendar, from the wife, today.
View attachment 427315 View attachment 427337 View attachment 427338
You won't be able to weld with it unfortunately as you can only weld with acetylene. Brazing no problem though.Used but never used small gas welding setup. I want it mainly for automotive uses really putting lots of heat into small bolts etc
View attachment 427381View attachment 427382
£50 on fb was a good enough reason to go get it and will let me try out gas welding / brazing too.
Haven't tried it yet but going by gaztube they will weld and it says so on the stand alsoYou won't be able to weld with it unfortunately as you can only weld with acetylene. Brazing no problem though.
I found similar to be very disappointing, could do lumi weld on small aluminium castings and probably ok for making jewellery but not up to freeing seized studs on a set of bike barrels just not enough heat.You won't be able to weld with it unfortunately as you can only weld with acetylene. Brazing no problem though.
