The_Yellow_Ardvark
I'm a citizen of Legoland travellin' incommunicado
- Going Away.
That's why a good one comes with a sliding jack.Try doing a FWD clutch on a 4 poster
Here yah go winchman it started as a Thwaites skip dumper and father wanted a forklift and as the tusker has great turning circle and the hydraulics it was the best way to go, also this one is electric start. Father picked up a Cameron Gardner tractor rear mounted forklift.I love the Dumper / Fork lift
. In the box was another lovely leather hitty hammer, and a bag of sweeties.
Why did you have 56lb weights on your head?Here yah go winchman it started as a Thwaites skip dumper and father wanted a forklift and as the tusker has great turning circle and the hydraulics it was the best way to go, also this one is electric start. Father picked up a Cameron Gardner tractor rear mounted forklift.
And I made up a frame copying the tusker digger frame so it can be removed easy if ever needed. It will lift more than we ever needed
I did make a weight box on the rear and filled it with 56lb weights off the top of my head there about 500lbs of weight in there which helps enormously
and if say I lift more than a ton and a half I stick some breeze blocks on the back box. Heaviest I have lifted is about 2 ton. Father’s happy with it best bit of kit on the plot.![]()
But have you actually tried doing one?That's why a good one comes with a sliding jack.
A name I have not came across before...
Yes.But have you actually tried doing one?
Cameron Gardner used to be not far from us. Closed years ago.Father picked up a Cameron Gardner tractor rear mounted forklift.
A Name I have not came across before.
[@Agroshield beat me to it with the link
]Is that mail order or local rep?Some special offers from Wurth atm,don’t know if you need an account,these cutting discs were only 30p each!View attachment 287665
My dad had those b&d bits and a bench grinder one too. I have the drill but nothing else. It’s strong as hell. Nothing like the modern crapMore stuff I didn't know was in there:
Today I acquired - a new printer.
Well it's not new but nearly new just reporting an error. Guy at work lost his rag with it and got a new one. I brought it home and found an air duster straw inside preventing the print head from parking properly.
Mine for a couple of hours fault-finding - £300 new![]()
