I guessed he might be in France?
Ons of the most useful excavation tools I have bought
Useful bit of kit - I have the exact same one. I have plans to make it faster tho.Today I acquired a belt sander from a skip.The Vark must have had a lay in
Bob
Well done for remembering to get the food shop while you were there!
Agreed. I may use it on my surface grinder for a similar purpose.Looks like something I'd use on a tool and cutters grinder
What's better than freeing up space?
Filling it back again
I'm now the proud owner of this 3/4" Gedore Rahsol Dremometer torque wrench in the 140-760Nm range View attachment 508161
Seriously I don't need something like that often but after having had to count every single Nm over the maximum torque on my half inch to get the remaining 30 needed to reach 240 and correctly torque the axles on my little Punto.
I wanted something capable of higher torques.
Said that it'll be much easier to torque something using this one than using my half inch.
As it has a longer lever.
Example 180Nm on the 1/2" will be around 30kg of applied force at the handle.
While on this something like 22kg.
And for someone skinny like me it's an huge difference
I can even do the math on the threads to find the angle neededTo do hub nuts I have a mark on my breaker bar and I know if I lean all my 80kg on the bar at that point it is the correct torque.
Just convert your weight to newtons and do some maths to get your distance.
I hope you've built the shelving in its final resting place. There will be a lot of swearing if you have to move it.View attachment 508185metal shelf assembled still have a lot to do but I'm done for today
It's final place as it's the only location that allows me to store things and park the toolbox in front of it without interfering with the benches or movements inside the small shop.I hope you've built the shelving in its final resting place. There will be a lot of swearing if you have to move it.
Is that food compatible?Some colour changing filament.
In theory it goes from blue to white at ~30°c just gotta find a use for it, seen some use it for electronic boxes as good overheating indicator/looks cool but otherwise no idea what to print!
