Funnily enough I had a conversation with a paint and coating specialist over dinner here last night about just this thing - I have a number of similar looking tins from a similar date. Basically, if they are solvent based, they should be good for as long as their is solvent in there.Free can of paint. Yes, I know it is old.
Any idea what it is? If I can just slap it on old tools/projects I'll be happy.
There was a whole cupboard full of similar paint + associated stuff but I'm pretty clueless about paints. I'll give this a go. Any idea regarding suitable thinners? I can't find info online.Funnily enough I had a conversation with a paint and coating specialist over dinner here last night about just this thing - I have a number of similar looking tins from a similar date. Basically, if they are solvent based, they should be good for as long as their is solvent in there.
Water based stuff simply doesn't keep - bugs in the water cause it to stink, and they eat the fillers used to bulk it up.
Are they supposed to be burnt in as there is no metal collar?Makita UH006G hedger. This one has a slower, torquier gearing and wider "rough cut" tooth spacing. Feels much lighter than the pro Stihl ones, less vibration and should have more power.
Genuine 3Ah LXT battery and a load of covers for the fakita batteries. The LXT charges nicely on the XGT charger with adaptor.
Also two more! A 2.5Ah XGT battery, which is much closer in side to the LXT, near half the size of the 5Ah, and half the weight!
Pferd chainsaw files, handles and a tool strop. Sadly the idiots once again made the file handle holes far too big for the files tang, so rather than being properly burnt in, they will have to be epoxy glued in.
I have the older Makita hedge trimmers, and knocked the crap out of them, but still going strong, can do 25mtr of 6ft high leylandii both sides and top on one 5amp. happily handles the thicker bits of yew as well.Makita UH006G hedger. This one has a slower, torquier gearing and wider "rough cut" tooth spacing. Feels much lighter than the pro Stihl ones, less vibration and should have more power.
Well, they've slashed away ALL the greenery, Trees and shrubs along about 40 miles of railtrack, saying it was for 'safety'. The arrived at 2am with a rail carriage fitted with a grabber and cut down all the trees. Chainsaws all night long. I discovered they had also entered our garden, cut down our fence, removed several stands of Ash and Maple and the F'd off with it. Strangely, one of the workers then offered to sell me some logs (presumably my own Ash?). Nobody bothered to tidy up the remnants of the Bat boxes that had been knocked out of the trees.Not nosey, 'interested'.
Same here plus pictures.
Seadog I've just acquired a Tapmatic 70 x , have you a manual for it , be much obliged for a peak at it , need to order a few bits , colletts and a small bearing and a spring , need to know stuff to ask for !A few parts for my Tapmatic rebuild
Two annoying things, apart from the cost
The first item I didn't need (£22.50)![]()
The spring that I ordered was the wrong one
I now need to persuade Tapmatic to swap the spring and give me a refund (no doubt a part-refund) on the washer,
and in addition pay postage both ways...
I haven't opened it yet. Snowed under with a miriad of other jobs today.International deny all knowledge of Interlac 845.
The 80-78 may refer to it be flame resistant finishing coat.
Unless it is the paint Reg Varney nicked from the bus depot, I'd just try it.
Is it still liquid or a green door stop?
Don't let any children near the printer. They'll label everything in sight, kettle, toaster, you if you stand still.Today I acquired a new hand held label printer that can print on heat shrink and some cobalt drill sets.
Bob
Cat, hamster ants(did not go well)Don't let any children near the printer. They'll label everything in sight, kettle, toaster, you if you stand still.
There are severe penalties for disturbing bats and their habbitat. Very big fines, I suggest you contact the forresty commision/enviroment agency - sorry cant remember who of the top of my head...Nobody bothered to tidy up the remnants of the Bat boxes that had been knocked out of the trees.
I'll send you the info that I have.Seadog I've just acquired a Tapmatic 70 x , have you a manual for it , be much obliged for a peak at it , need to order a few bits , colletts and a small bearing and a spring , need to know stuff to ask for !
Thanks
