brightspark
- yarm stockton on tees
Sounds like you need an hydraulic lift there fella![]()
let me guess errr u might be the person that just might have one 4 sale
Do you possibly have something that could help?![]()
Not a far as I can see, its in the outlet shown on the left and it has an internal screw thread to take a pipe, it sits at the bottom of that hole, probably held on place by similar 50 year old gloop that the rest was, the difference here is that I can't get to push it out from underneath. I could possibly shift with some air, carefully dodging the high velocity bullet ti could become![]()
all i do with mine when it gets oily and dirty is cover the motor and electrics up .steam clean it off tape the moving parts up with masking tape and spray it with hammerite that i got from autojumble for a tenner for half a gallon
it works for about 10 years the only service it recieves is clean the guide bars regularly and oil them and grease the crank bearings and conrod regularly the odd clean and thats it mantenance free
Those holes were likely slight casting flaws. A water based cutting fluid might well have corroded the casting too, making them worse. You can just see the start of pinholing in those first photo's you posted for that casting, where that second hole appeared. The heat from the welding will have finished that hole off.
Was all of the metalwork so clean when you got it, or have you blasted the metal after stripping it?
You never said but I take it the 90 degree marks matched up when you swapped the jaws?
