Try tensioning the spool so that it just prevents overrun on your fastest wire speed. This should be adequate. As far as ill fitting adapters go, I have used offcuts of drain pipe as packers, notched to fit.
Try it on Argonmix gas instead of CO2 & it will seem like a different machine
weldequip
Right potentimeter used in my welder is a 2K2A - well thats whats written on it)
You could rig it up to run from disposable gas canisters, just to try it on Argonmix. I know disposables work out expensive but, trust me, you'll notice a huge difference in performance...and might wonder why you've gone to all the trouble with the modifications(Don't get me wrong, a change in gas won't cure the inherent problems with some SIP machines, but the proper gas makes all the difference).
weldequip
- think of it like learning to drive a car with no power steering, no ABS and a crash gearbox - thats what I learnt in - it was hard work and difficult but ultimately you understood clearly what was happening as a result of your inputs.... I'm not saying it makes me a better driver but a clutch cable snapping 100 miles from home didn't result in a call to the AA and services of a flatbed - I just carried on driving without the clutch matching revs to speed thro all the gears.
Hi,
I've been reading this with interest and congratulate you on your staying power, beating this is a personal goal now. Probably what I would be doing too.
I have really only a couple of question to ask....
If you were to cost your time
(researching time),
(collecting materials/components time),
(time to fit said materials/components),
(time lost because of defect materials/components),
(time lost in identifying said failed materials/components),
and the raw cost of materials/components,
how much would you say the additional are standing at the moment?
Then what the machine cost initially?
What's the total?
I'm not having a go at you, but I think it's important to know the potential REAL cost of these 'good value for money', 'they join metal together' type units is. Thanks
I'm also enjoying the thread. I bought a used SIP just to see what everyone was on about.
Experimented a bit but slowed up a little as what I really wanted to do was measure the speed and voltage variations in real time.
One thought though - have you considered pulse width modulation for the speed control? http://www.mig-welding.co.uk/forum/showthread.php?t=4481 Advantage is it ought to give the motor a little more torque, and ought to be less prone to speed variation through heat than the original.
I like the idea of the multi-turn pot. It'll look good.
