Probably. It's quite niche nowadays but try finding your local Engineering works that still carries out the process. Perhaps they'll take them off your hands.Is there much call for white metal bearing material these days? I found a few ingots in the shed at the weekend.
They don’t make ‘em like that any more ................... damn good job too![]()
Glad you got the piston rings in OK . At least the valve clearances are adjustable unlike some of the old Ford sidevalve engines , they had a lump on the tip of the valve and used split valve guides, to reduce clearance you recut/lapped the valve /seat To increase clearance you removed the split guide to get the valve out then reduced the length of the valve.
2 bearing crank, daft idea. Three, now that's the answer....
I seem to recall, early 7’s were 2 bearing & later ones were 3. The 2 bearing ones, if you were tuning it, you shaved the middle 2 piston tops to take up the crank whip at revs. I’ve never had or taken apart a 7, just what I was told by those that had. I’m sure someone will be along soon with the full story.There you go, I allways thought they were 2 bearing. Learn something every day
Minor issues on a Morris? Like what you did there!"
@RWD3M Is that a GT6 lurking there?
