Me again, more odd behaviour :(
  1. Brad93
    Brad93 M J B Engineering
    8,508
    Essex
    The gas does not settle if used within a normal time frame. I wouldn't say a year is a normal time frame.
  2. addjunkie
    addjunkie Member
    5,995
    Northumberland. Reet oot in the sticks
    I had my last full size bottle probably 4 years, hardly used for 2 of them while I worked away and rebuilt a house at the same time.
  3. Davek0974
    Davek0974 Arse!, Drink!, Girls!
    919
    Hertfordshire
    So, whats the best option here - smaller cylinders? different gas?
  4. pedrobedro
    pedrobedro Man at Matalan
    10,384
    CX Derbyshire
    I've got a big 5% cylinder that I connect to when in the shed and it's been stood there over 8 years and still welds fine. It never gets shaken either.
    slim_boy_fat likes this.
  5. HughF
    HughF Member
    5,707
    Work: Dorchester, Workshop: Corfe Castle, Wife's place: Frome
    Never shaken a bottle, never experienced the settling... sounds to me like you're cooking the contact tips as others have said
  6. Brad93
    8,508
    Essex
    Maybe you’ve got a bad bottle of gas, and you’ve been having the same problem for a year?
  7. Davek0974
    919
    Hertfordshire
    The tip is as clean as it was when fitted. This is not a tip problem, the shroud is also mint.
    Its not overheating either - i can and have done many long practice beads without fault and then some days you can do 1" and it will start.
    Its not the welder as i have changed machines from R-Tech to ESAB and the behaviour returned.
    The only common denominator is - Gas, Me, Electicity, everything else has changed.
  8. Davek0974
    919
    Hertfordshire
    That why i am blaming gas - the last time it happened on the R-Tech the bottle was way down so i got a refill and all was well, this one is half done and gone bad again - if i am having to waste 50% go the gas by early refills then a smaller cylinder should help?
  9. Davek0974
    919
    Hertfordshire
    Just an update, been a while.
    I still get this fault occasionally - i can tell when its going now and the easy fix is to grab a lump of scrap and run bead until the fault clears - usually in 5 - 10 seconds, then it will not return that day.
    Still no idea what it is though but given up worrying about it now. Everything has changed apart from me and the electricity :)
    I did notice after one flare up that the voltage used on the Rebel display was way higher than usual - I think its usually 17-19v and after a flare up it was around 26v.
  10. Brad93
    8,508
    Essex
    Have it back under warranty sounds dodgy to me
    arther dailey and eLuSiVeMiTe like this.
  11. Davek0974
    919
    Hertfordshire
    Its not the welder, I sold a perfectly good R-Tech Mig 160 because of this fault and bought the Esab - the issue remained!
    Different gas, different wire, different machine.
  12. Brad93
    8,508
    Essex
    It’s your power supply then
  13. Davek0974
    919
    Hertfordshire
    Its possible, but I would like to know how - I have a good grounding in electronics and power supply and fail to see how it could be that doing this, there is no light dimming, no interference on radio - the plasma cutter uses more power and that runs fine.
    Baffling
  14. Brad93
    8,508
    Essex
    You need to see if you’ve got a voltage drop. You’ve got the same issue on two welders the only thing that leaves is power supply. Maybe you get spikes?
  15. Davek0974
    919
    Hertfordshire
    Possible, but the plasma is far more sensitive and runs cutting far longer than i run welds for and its not had any issues.
    Not easy to monitor without some sort of data logger, interesting though.
  16. Richard.
    Richard. Forum Supporter
    18,348
    Cambridgeshire
    You’ve had this problem follow suit with 2 independent welding machines for a number of years and you haven’t tried it on another supply to rule it out????
    I still cannot believe it’s an issue after this length of time. Have you actually tried anything to resolve this or are you just hoping a snake falls out of the wire feeder one day and that’s problem sorted. No offence but if it’s not the actual machine then diagnosing the underlining issue could be very easily done in a matter of an hour with process of elimination. Ie supply, gas, torch, you.
    eLuSiVeMiTe likes this.
  17. Davek0974
    919
    Hertfordshire
    Checked for snakes - all ok ;)
    It's not the gas - tried BOC and now on HobbyWeld5.
    It's not the torch - two different machines/torches.
    I could try elsewhere but it has a 20A plug and being a home workshop there are no other outlets. Its not a regular occurrence and one thing i have noticed is that the more i use it the less it happens. Sometimes i might only make two welds in a fortnight, others it could be every day, very random demand.
    It might be air leaking into the system during downtime but I always give it a bit of a purge when i turn on so not sure of that - how long would it take to purge from bottle to tip?
    It's an issue but not an important one any more, just baffling now.
  18. arther dailey
    arther dailey Member
    3,991
    England
    Way Way back(2017?) you said it welded perfect even with reg set at 1 lm rather than the norm,6/8ltm, I suggested then(this might be with your old welder) that if thats the case your regulator is fuba, have you got a new reg since??
  19. dobbslc
    dobbslc Forum Supporter
    5,287
    Hertfordshire UK
    Have you checked all the electrical connections live, neutral, and earth's from the main house D/B through to the.welder outlet?
    Could be a loose terminal, I've had this at work when something works fine one minute then goes screwy the next. Worth a check as it might save your house burning down.
  20. Davek0974
    919
    Hertfordshire
    Yes, binned the old one.
Advertisements
