arther dailey
- England
07 should be the m9r engine in which case you may get lucky in getting the engine hot hot. The oil filter housing expands slightly and then can release.
If not the hammer and screwdriver to pierce a hole. Snap the rest of the cap off then lever the threaded part off and replace the cap.
shame I already drained the oil !, but sounds a good idea, if I use a hot air gun on it to get top hot, will have to be carefull though its soaked in oil as steering pump had gone, replaced that ok, just thought oil and filter wont take ten minutes while ime here,ha . after that its sort the abs light on, presume,well hope its a wheel sender. Thanks
