arther dailey
- England
Got to change the filter on a 07 renault 116 dci van, now the oil filter is a paper element which is held in by a plastic cap, nice design as it has a 27mm nut moulded on....untill you try and undo it ! I can see the cap plastic twisting without it undoing, so obviously well tight/stuck, I used a socket on the nut and a chain wrench on the body, the body just starts to dent in. hmmmm see now why oil hasnt been changed for years
before I break it any of you guys got any special way to remove the SOAB, looking on net theres a tool which grips the canister as you undo it, with two wide semi circle legs, this looks best bet as the 3 legged sort would certainly crush it without probably undoing it.
advice if you have coquered this before much appreciated. Arther
, but sounds a good idea, if I use a hot air gun on it to get top hot, will have to be carefull though its soaked in oil as steering pump had gone, replaced that ok, just thought oil and filter wont take ten minutes while ime here,ha . after that its sort the abs light on, presume,well hope its a wheel sender. Thanks
