arther dailey
- England
Got to change the filter on a 07 renault 116 dci van, now the oil filter is a paper element which is held in by a plastic cap, nice design as it has a 27mm nut moulded on....untill you try and undo it ! I can see the cap plastic twisting without it undoing, so obviously well tight/stuck, I used a socket on the nut and a chain wrench on the body, the body just starts to dent in. hmmmm see now why oil hasnt been changed for years
before I break it any of you guys got any special way to remove the SOAB, looking on net theres a tool which grips the canister as you undo it, with two wide semi circle legs, this looks best bet as the 3 legged sort would certainly crush it without probably undoing it.
advice if you have coquered this before much appreciated. Arther
