You need to a hex socket on them, if you try with a normal 12 point you will chew it up. If you have the right socket it's scary how much load you have to put on them sometimes.
If it's the O ring binding then sometimes you need to hold them under tension and they will start to move.
Similar to a lot of vans iirc it's less than. A tenner
when it stops raining was thinking on using a hot air gun, so basically a over powered hair drier !on the top part.. Thanks Artherdid you try the hair dryer ? for heating ?
I have several different types of filter wrenches including a couple of sets of the cup types. I have specific set of low profile sockets for the plastic housings.
I have one of these and I have found it will grip normal spin on filters that other won't.They work well because they don't focus the leverage in single spot as much as other designs so they tend not to deform the cannister as much. For me the normal issue is doing a vehicle I've not touch before and someone else has goosed it up.
https://www.thetoolacademy.com/laser-3328-oil-filter-wrench---metal-band-1258-p.asp
Personally I would just put the new oil in and get the vehicle running, often these paper cartridge types with socket tops are in a position where you can change them without draining the oil so you could just do it another day.
as ever, whats iirc ?....
If I Recall Correctly - comes from the days of "txt speak" on early mobile phones when text messages had limited character count.
There was a thread on here years ago with a lot of the abbreviations.
) , then got under to remove oil filter, normally as we all know a two minute job...Ha so yes it might be remove all the front,get the bumper of somehow,remove complete assembly ,then get it apart ,but by taking it of the van you will no longer have it secure enough to get the leverage needed to unscrew the ..... thing, but with bumper off it would be very much more getattable.......07 should be the m9r engine in which case you may get lucky in getting the engine hot hot. The oil filter housing expands slightly and then can release.
If not the hammer and screwdriver to pierce a hole. Snap the rest of the cap off then lever the threaded part off and replace the cap.
,arrived this morning in the post, ordered before I went mad at it..fitted,filled and thankfully running .
