can you give your monthly and yearly quota by any chanceFor anyone needing some real world info for solar panel “effectiveness” to help with decision making here is my latest stats page.
System is 7kw installed panels (don’t remember the brand).
SolarEdge 8000h inverter. Enough headroom to add more panels in future if necessary.
SolarEdge optimisers on each panel.
SolarEdge 10kw battery.
In short,at the moment, solar is providing about 75% of our consumption.
The panel degrades slightly in terms of efficiency over time. The manufacturers publish figures for this. So destroy is the wrong word.This guy reckons the sun destroys solar panels??? skip to 2:25
Agree, good info, well presented.I’m sure someone will be along shortly to tell you not to bother as solar doesn’t work in Britain
Fantastic job as always @brewdexta - can’t wait to see the results.![]()
Solarsparky (tradesparky) are listing about 6-10 weeks for inverters.Solar edge are fantastic, great inverters and the dashboard is one of the best
However I've just been quoted 8 months lead time for inverters
But they have 100+ batteries in stock:-)
They are showing 10 weeks for the big one (82kw) too. But worth calling to checkI always forget when replying to these I'm not looking at domestic stuff, usually it's 50kw+ inverters
you would be far better off digging in the fronts and using the screwed bar at the rear to adjust the height of them
or you have a middle bar that swivels and adjusts from either the front or the rear
i believe from his other thread posts that was his barn/workshop that hes posted on hereIs that sheet metal roof your barn? What direction does that face? I wonder if my live stock building is strong enough for panels one side is about 5 degrees off due south!
AmI correct in thinking that if I have batteries and dont export any more juice than my existing 4kw system I could have as much as I wanted.
