Pigeon_Droppings2
- london
Could you buy 9mm and then just remove the top layer maybe?Except its an oddball thickness of 7mm,
A sheet of 8mm Robbins elite ply is £92 then there is £225 delivery & £63.38 in vat taking it to a grand total of £380.30.
May the itching will have stopped by the time you are back.Got the bulkhead out...was a faff due to the limited access. Bracing was either totally unnecessary or held well!
I'll be back at work next week so progress will only be when I can get time at weekends.
I found this out the hard way after I had bought the ply and cut it to sizeRe Plywood, most so called marine ply today is garbage
.Cheers for the info...I'll take a look. I'd really prefer not to use ply but I'm amazed how few alternatives I'm finding!i have found is PET foam which is the same stuff that plastic drinks bottles
Think I'm going to stick with ply with this one...the boat isn't a keeper so I reckon ply will be easier.
Reason it isn't a keeper is that it's a fixed keel which makes launch/recovery more hassle. I'd have preferred a drop keel if I had the choice again.
I looked at the PET....I think that's definitely the way to go...it's a more permanent solution where as the ply will need redoing in future (but not by me!!)
Did the ply have the BS 1088 on it.So I've cut my bulkhead...was just going to seal the edges with epoxy and I happen to see this!!
I thought the whole point of marine ply is that there should be no voids for water to get in!
Now I'm thinking this board is not so good?
