prepman
- Gwynedd UK
Don't have the white meter (or a working SMART one)I switch to immersion heater during the summer too, heat it on off-peak overnight and the tank normally lasts the day![]()
Steel corrosion or copper? With copper provided water ph is >7 then not an issue. Copper oxide forms (brown). However with acid it forms a verdigris (green) which leads to a holed system. Brass de-zincs and crumbles like a 'Crunchie' bar. I have a ph corection vessel filled with 'Juraperle' for my spring water supply. Steel will be attacked by dissolved oxygen. Passivation reduces it.I suffer from the same problem, water is heated by immersion heater but pipe run means it is well over 2 bowls before I get warm water. However I wonder if going to one of those "electric geysers" and leaving the hot tank and pipes to go cold, would lead to corrosion in both, as I heard that it is the heat that stops oxygen in the water from doing damage. Anyone know if this is true.
DunNOAren't some of them accessed via the DNO infrastructure?
A lot of the electricity companies went bust recently.Been thinking about this a lot lately. If the likes of BP are making billions extra out of our misery with their exploitation of the fuel crisis, how many billions of extra profit are the electric companies making? When do we get to see their sales figures?
At my old place I had a hot bath every night, filled to the brim, as hot as I could bear. For a test I once had a shower with the plug in, and it only filled the bath 3" deep. Where I am now there is only an electric shower, so I'm pretty glad really. My bulk lpg bill would be far, far higher if I had a bath tub here.Quite honestly I would be more than happy to remove the loft tank, pipes and wiring as they will never be used again, but will leave as is unless there is a problem. Had the bath removed and a shower unit installed so no need for 20 gallons of hot water.
Britain gets around 45% - 55% of it's electricity from gas - the price of gas went nuts because of Putin.EDF supplies a lot. In France their
Electricity has gone up less than 5% Funnily enough the trend with EDF supplied energy here doesn’t follow the same .
Increase in the U.K….. 54%Profiteering here we go again
thats exactly what we have so +1. They are really good. I’ve one in the house that feeds the kitchen sink and bathroom handbasin.Because of the problem of heating a loft immersion tank and using 5 lt of water before it ran hot , I had an under sink heater fitted just over a year ago. Best thing I ever did. I even asked my plumber about putting one in the bathroom, just for the sink, but he came up with the alternative of t piecing the current unit it the bathroom at a quarter the price. Works perfect. There are valves on all feeds so only a minutes work to switch back to the loft tank. Far more economical to heat 15 ltr to wash hands or dishes now.
Ariston Andris Lux Undersink Water Heater 3kW 15Ltr - Screwfix
Order online at Screwfix.com. Undersink. Frontal knob for easy temperature regulation. Robust internal 4-bolt flange for increased durability. Steel Tank with Vitreous Enamel Coating. FREE next day delivery available, free collection in 1 minute.www.screwfix.com
Yes but that is all we have - 8. They only provide 14% of Britain's electricity!
French government fixed gas prices last October and limited electric price rise to 4%. So at some point, when they will get hit with a pretty big rise!EDF supplies a lot. In France their
Not really there are agreed rates. If Britain had 100% nuclear power we wouldn't be at the mercy of the Saudis or Russia... and are no longer under British control so they can pull our pants down at will
Our ~ 10 year old gas boiler is on for about an hour each day and since the heating went off I've been keeping an eye on the gas usage, so for the last two months it's averaged out at 0.57 cubic metres per day. That gives enough hot water for 3 showers and any general washing up etc.i normaly use our gas boiler to heat the water tank . im thinking it might be cheaper to use the emersion heater as the boiler and pipes have to heat up with the gas every time its calling for heat .the tanks lagged and immersion heater in it with thermostat .. anyone any thoughts on it![]()
Efficiency = useful energy out ÷ total energy in
I got 5.25kwh of heat output in the hot water and put in 6.4kwh of gas.
So I the system is 82% efficient, the type of boiler is not relevant in the equation.
France price limits are mainly down to the fact their utility suppliers are state owned, their government is footing the bill. From an article below…
"Somewhere like Germany has looked to scrap surcharges on its electricity bills. France has done something quite different, because it's got a nationalised energy supplier with EDF, it's taken quite a different tack in terms of limiting bill hikes to only 4 per cent. The government is essentially forcing EDF to sell electricity from its nuclear plants at a below market rate to other suppliers. So that's something we can't do in the UK. We got rid of our nationalised energy system a long time ago.”
Hardly expoitation, BP accept what others are prepared to pay for their products. Couple of years ago nobody wanted petrol/diesel and they made a loss. As for electric companies, depends on what you mean, the ones you pay for your electricity, made a loss last year, which is why many went broke, because the price cap was lower than what they had to pay their suppliers for electricity. The "big six" mostly survived because they generate electricity too, so while the retail side made a paper loss, the generator side mostly made much more profit. Gas generators didn't, as they had to pay more for gas but Nuclear and the renewables costs didn't go up much, so got a windfall. I assume this is what the windfall tax will fall on. The energy market was always flawed. Right from privatisation it was never going to work for the benefit of consumers. Because gas generation costs more, the retailers were willing to pay the renewable generators more. However the renewable generators were getting all sorts of incentives to grow, that is what the "green levy" is for, so consumers end up paying the green levy which producers no longer need, extra standing charges, to upgrade the system, which the green levy was also for, and more for their electricity, part of which is supposed to be going into "investment in infrastructure" so consumers pay three times for the same thing, neat trick.
