prepman
- Gwynedd UK
Don't have the white meter (or a working SMART one)I switch to immersion heater during the summer too, heat it on off-peak overnight and the tank normally lasts the day![]()
Steel corrosion or copper? With copper provided water ph is >7 then not an issue. Copper oxide forms (brown). However with acid it forms a verdigris (green) which leads to a holed system. Brass de-zincs and crumbles like a 'Crunchie' bar. I have a ph corection vessel filled with 'Juraperle' for my spring water supply. Steel will be attacked by dissolved oxygen. Passivation reduces it.I suffer from the same problem, water is heated by immersion heater but pipe run means it is well over 2 bowls before I get warm water. However I wonder if going to one of those "electric geysers" and leaving the hot tank and pipes to go cold, would lead to corrosion in both, as I heard that it is the heat that stops oxygen in the water from doing damage. Anyone know if this is true.
DunNOAren't some of them accessed via the DNO infrastructure?
A lot of the electricity companies went bust recently.Been thinking about this a lot lately. If the likes of BP are making billions extra out of our misery with their exploitation of the fuel crisis, how many billions of extra profit are the electric companies making? When do we get to see their sales figures?
At my old place I had a hot bath every night, filled to the brim, as hot as I could bear. For a test I once had a shower with the plug in, and it only filled the bath 3" deep. Where I am now there is only an electric shower, so I'm pretty glad really. My bulk lpg bill would be far, far higher if I had a bath tub here.Quite honestly I would be more than happy to remove the loft tank, pipes and wiring as they will never be used again, but will leave as is unless there is a problem. Had the bath removed and a shower unit installed so no need for 20 gallons of hot water.
EDF supplies a lot. In France theirA lot of the electricity companies went bust recently.
Britain gets around 45% - 55% of it's electricity from gas - the price of gas went nuts because of Putin.EDF supplies a lot. In France their
Electricity has gone up less than 5% Funnily enough the trend with EDF supplied energy here doesn’t follow the same .
Increase in the U.K….. 54%Profiteering here we go again
thats exactly what we have so +1. They are really good. I’ve one in the house that feeds the kitchen sink and bathroom handbasin.Because of the problem of heating a loft immersion tank and using 5 lt of water before it ran hot , I had an under sink heater fitted just over a year ago. Best thing I ever did. I even asked my plumber about putting one in the bathroom, just for the sink, but he came up with the alternative of t piecing the current unit it the bathroom at a quarter the price. Works perfect. There are valves on all feeds so only a minutes work to switch back to the loft tank. Far more economical to heat 15 ltr to wash hands or dishes now.
Ariston Andris Lux Undersink Water Heater 3kW 15Ltr - Screwfix
Order online at Screwfix.com. Undersink. Frontal knob for easy temperature regulation. Robust internal 4-bolt flange for increased durability. Steel Tank with Vitreous Enamel Coating. FREE next day delivery available, free collection in 1 minute.www.screwfix.com
Yes but that is all we have - 8. They only provide 14% of Britain's electricity!
French government fixed gas prices last October and limited electric price rise to 4%. So at some point, when they will get hit with a pretty big rise!EDF supplies a lot. In France their
.. and are no longer under British control so they can pull our pants down at willYes but that is all we have - 8. They only provide 14% of Britain's electricity!
Not really there are agreed rates. If Britain had 100% nuclear power we wouldn't be at the mercy of the Saudis or Russia... and are no longer under British control so they can pull our pants down at will
Our ~ 10 year old gas boiler is on for about an hour each day and since the heating went off I've been keeping an eye on the gas usage, so for the last two months it's averaged out at 0.57 cubic metres per day. That gives enough hot water for 3 showers and any general washing up etc.i normaly use our gas boiler to heat the water tank . im thinking it might be cheaper to use the emersion heater as the boiler and pipes have to heat up with the gas every time its calling for heat .the tanks lagged and immersion heater in it with thermostat .. anyone any thoughts on it![]()
