angellonewolf
- bristol england
if your going pimp your band saw gold leaf ?
I'm going to assume you mean Methylene Chloride if only because all the noVOC strippers say they don't have it!
Playing with chemicals is super dangerous because without a wider knowledge of the subject, it would be easy to make a simple mistake that could take a chunk out of your life expectancy. Having said that, I have used the real Nitromorse many times over the years and apart from the occasional burn (!) no harm done. I'd still like to find some rather than mix up my own cocktail!
Apparently it is highly solvent and will evaporate in no time. Methyl cellulose was part of the recipe and thats basically wallpaper paste so I guess i'll be making up a cocktail and see how it goes.
I am pretty sure my 3M mask must have some active filter in it because I was able to finish painting the bandsaw (with Cromadex/xylene) without the headach and nausea. I will double check what filters are in there but this bandsaw is the final test before I start work on the Bridegport and having a decent paint stripper will help that process tremendously.
Safety first!![]()
I'll look into getting the correct filter. I did like the smell of the old Nitromors (!) but iirc it didnt half give you a stink in the nose. What do I need to look for? Acivated charcoal for volatile organics?
No, I am suggesting mixing up Methylene Chloride with Methyl cellulose to thicken it up. I suspect that is 90% of what Nitromors once was.
Mixing two things up could be dangerous, my chemistry when it comes to mixtures isn’t very good at allI'll look into getting the correct filter. I did like the smell of the old Nitromors (!) but iirc it didnt half give you a stink in the nose. What do I need to look for? Acivated charcoal for volatile organics?
Pretty sure it will be fine.
I was going to say "whats the worst that could happen" but you're the last person I'd ask!![]()
You want a large steel drum, tip in the DCM and then several inches of water poured on top. The water provides an anti-evaporation layer. Top up as necessary.
I was determined not to strip the motor too far. Just enough for a lick of paint. Looks pretty good all things considered.
I thought I'd pop the bearings off so I could order up some new ones. They won't shift. Does anyone know for a fact what size they are?
Are you suggesting a dip tank?
Worst? You end up producing phosgene poison gas, like the Bosch used on my grandpa in the trenches... He did survive it, but they wouldn't let him fight in WW2, had to earn his George Medal another way...
I buy my methylene chloride by the gallon, mix it with "modern" strippers for the surfactant / cling properties, BUT - gloves, faceshield, outdoors out of direct sunlight (see above) with a breeze to carry the fumes away. If you smell new-mown grass while using it, get well upwind and everyone out from downwind...
Dave H. (the other one)
