chassis protection
  1. Can you post a link - I can't see it anywhere?
    Dcal likes this.
  2. 123hotchef Member
    9,014
    Kent
    yes sure give me 5
  3. 123hotchef Member
    9,014
    Kent
    @JonnyAlpha https://www.ebay.co.uk/itm/254290858180 sorry i forgot
  4. 123hotchef Member
    9,014
    Kent
  5. 123hotchef Member
    9,014
    Kent
    ok i am having a bad time stripping the 3m underseal off it wont strip with stripper or thinners it wont sand it wont grind any ideas? of can i just paint jotun over it?
  6. Dcal
    Dcal Forum Supporter
    1,819
    Antrim Northern Ireland
    Sharp wood chisel will take the worst of it off then a wire brush in a grinder for the rest
    123hotchef likes this.
  7. Dcal
    1,819
  8. 123hotchef Member
    9,014
    Kent
    Doh.
  9. 123hotchef Member
    9,014
    Kent
    Even the wire brush makes a mess and it.ends up melting and collecting where the brush isint
  10. Dcal
    1,819
  11. 123hotchef Member
    9,014
    Kent
  12. arther dailey Member
    3,724
    Southampton England
    have you tried warming with a heat gun ?
    Dcal likes this.
  13. Ashley Burton
    Ashley Burton Member
    3,486
    Northamptonhire
    I was just about to say heat gun & chisel
    I used a wire wheel on my grinder, It might be messy, But it works
  14. Dcal
    1,819
    @arther dailey beat me too it but - Is the 3m hard?
    Have you tried a hot air gun and a chisel?
    That's why I personally don't like the single pack 3M or Gravitex type stone-chips.
    However the up side is if it's hard you could overcoat it with 87A.
    The epoxies are brittle compared to factory stone chip and may crack if applier over them, also you will not get the corrosion resistance of the epoxy unless it is applied to the bare metal.
    It is an excellent barrier so you will get some benefit.
    If you are having a hard time removing the stone-chip it may be OK but you never know whats hiding under it and if it's gumming up a wire brush it isn't properly hard.
    If you do decide to apply 87 over the existing stone-chip clean all the grime of it, sand it well, clean it again and apply.
    3m do a 2 pack which is brilliant but hugely expensive.
    Wurth, sika and dinatrol all do one that stays softish I think.
    I've used the sika and it worked well, @RaceDiagnostics had excellent results with the dinatrol (I think)
  15. Ashley Burton
    3,486
    Northamptonhire
  16. 123hotchef Member
    9,014
    Kent
    Yes the 3m stuff has been on 5 years now pretty hard yes. I will try a gear gun and scraper or chisle later and report back. Good idea thanks guys.
  17. Burdekin
    Burdekin Chief Bodger
    5,009
    Aberdeen
    Petrol and a scraper/chisel.
    fizzy and 123hotchef like this.
  18. 123hotchef Member
    9,014
    Kent
    I tried thinners and a scraper it helped a little
  19. Burdekin
    5,009
    Aberdeen
    Try petrol, it’s softened the stuff I’ve removed and then just scrapes off. Not trying to remove it with the petrol, just gets it all soft.
  20. arther dailey Member
    3,724
    Southampton England
    if you have used petrol been damn carefull with a heat gun or your removal problem wont be the problem anymore....
    Ashley Burton and 123hotchef like this.
Advertisements
