brightspark
- yarm stockton on tees
komponentAs long as you understand that 2K only means 2 Komponent. It tells you nothing about the isocyanate content, which will be found in the material's data sheets.
Jotun epoxy primer for example, on steel frames (new angle iron) DIY friendly, brush able?
You only live twiceHi. I think that any body using 2k paints outside a professional spray booth with all the equipment is nuts.Too many body shop painter's have and are suffering from the effects of isocyanate with no recourse from employers or manufacturers
Stay safe people
That's not what this pdf saysNope. Not at all.
Most filter material is electrostatically charged to aid with the filtration. The charge dissipates over time reducing filtration efficiency. It’s why filters and respirators have an expiry date
FineThat's not what this pdf says
The electrostatic charging only applies to particle filters. The gas and vapour filters are absorbent, usually specially treated carbon grain and this will last longer if it's in a sealed bag when not in use, since it won't be soaking up passing gasses and vapours.
Epoxy primers are non isocyanate so can be painted with conventional PPE. Some are more suited to spraying than brushing, some are better for underside parts and some are better for bodywork, so it depends on your application. As for painting outside, you need to have an air temperature of at least 15C if you want it to cure in a sensible period of time.
The bottom line is that 2k and especially clearcoat lacquers,, should only be used with an air fed mask.
ive previously used it with 3m mask and cartridge filters which are supposedlly effective...they arent.
i spent a week in bed struggling to breath and shivering like a wet dog after getting isocyanate poisoning, and refuse to use a facemask now unless its airfed (and through a filtered air supply).
Anyone doing any different is a bloody idiot......
all the more reason to stay safe and just use air fed masks, no.?
i will not be using the cartridge filters again, its nothing to do with face seal, its to do with the fact that they dont prevent isocyanates from passing them.
3m even tell you not to use them, as does the HSE.
air fed for me, all the way, id like to see retirement.
That’s correct. Good for most organic solvents with the correct filter but they don’t filter isocyantesall the more reason to stay safe and just use air fed masks, no.?
Brand name? Tds sheets should be available to tell more...Last time this came up I started looking at UV curing clear coat. It's expensive stuff, but cheaper than an air fed mask setup. From what I've read it's as durable as 2k stuff when hardened, and on the plus side there's no fiddling with measuring cups and ratios either. I wonder if it's safer than 2k stuff or if it also contains isocyanates? If it does not, it could well be the way to go.
its not as expensive as you might think. air fed mask =£200, 3stage filter=£600
800 quid is a bit of an outlay
My lungs aren't great tbf.... Once had them checked at a booth in Croydon high street & the nurse asked me if I'd been a heavy smoker! I was 21 and had never smokedare your lungs worth £800?
800 quid is a bit of an outlay, but if you look at how much you will spend on mask filters (which arent recommended anyway, either by 3m or HSE, and are gonna be causing yet more harm) its probably a few years worth.?
or would you rather have breathing issues/asthma for the rest of your life?
Christ, i'm turning into my dad.......
