Eventually got the Polyurethane had messaged them asking when it would arrive but no reply and it is natural colour instead of the black it is supposed to be, won't be buying from them again.Be interesting to see how you get on with this, I've a few bits I wouldn't mind trying myself![]()
4000k, cheap 12v gu5.3 bulbsWhat colour LED light are you using ?
@Matchless may be a possibilityEventually got the Polyurethane had messaged them asking when it would arrive but no reply and it is natural colour instead of the black it is supposed to be, won't be buying from them again.
I should really have just sent it back but I wanted to try it out to see how things went and it was quite successful although I think I will modify the mould a bit to make pouring easier.
Anyway here is what came out.
Very flexible and seems strong as can be seen in the pics below I could easily stretch the neck which is 8.5mm dia over the 16mm ball and the 16mm shaft so that I could assemble things. The surface is slightly sticky but whether that will change through time I don't know.
I have ordered some 85 shore from a different place, also with black pigment so I will see what that is like but overall it seems like it will work for me.
I seem to recall that 24 yrs ago my pal was using red LED lighting on simple time clocks . It might be worth a bit of researching for winter egg production .4000k, cheap 12v gu5.3 bulbs![]()
I could but I will wait and see what the harder stuff is like. This is very soft, 20 Shore, I have ordered 85 Shore so ...Can you make a washer that has a rebate for the polyurethane but clamps on the base? Stop it coming undone too.
Thats a big jump from 20 to 85? i recon that might be a bit stiff said the actress to the bishopI could but I will wait and see what the harder stuff is like. This is very soft, 20 Shore, I have ordered 85 Shore so ...
I am sort of thinking that myself but thought I might as well go up a good bit and then I will be able to gauge what might be best. Seemingly 85 shore A is what tap washers are so with the thin section of the boot it may be ok.Thats a big jump from 20 to 85? i recon that might be a bit stiff said the actress to the bishop![]()
That is brilliant! A really inventive, interesting and original piece of work.Been working on this one for weeks but today it's finally gone outside to gain some rusty 'character'.
18" from tip of beak to tip of wing.
