As I don't use amy sticks I only used 44mm OD sink waste pipe in hard solvent weld plastic popped a removable twist to remove blanking plug on each end . The lids have an O ring seal in themI printed some capes that fit 80 downpipe to take welding rods.
From Thingiverse as a fishing rod holder. The screw cap has a hole in it, which i tapped M8 and put a bolt in it.
I cut a leather washer to seal the screw cap.
Its only 15 quid more than AMS1Some dessicant holders for my new ams 2 pro from additive-x. Thanks to @MattH and @Kram for putting me onto them as it was cheaper than bambulabs own website. View attachment 520397
I cant find it. I dont suppose you have the link handyI printed some capes that fit 80 downpipe to take welding rods.
Saggy gate wheel bracket, is a success.
Annoys me that the bottom front did not come out well due to using supports, so next time I will print the other way up, so it wont be visible.
Why? Not a feature as far as I know. Plus the lights were off and there's currently a bug on the Web page I think where you can't turn it on via the Web page when a print is running. Besides I was busy with other things.Surely the camera should have picked that up and stopped the print?
Broken the thermistor wires, they're only £20 off Amazon so I've ordered a new hot end, not worth messing about to be honest and I don't have the time.It's not damaged the extruder/hotend, has it?
If that is an Elegoo Carbon and you update the firmware and (possibly) the slicer it fixes that or has on mine.Why? Not a feature as far as I know. Plus the lights were off and there's currently a bug on the Web page I think where you can't turn it on via the Web page when a print is running. Besides I was busy with other things.
Is it an X1C though? Doesnt look like one to me.My lad's X1C detects if things go awry and stops the print.
