sako243
- My mansion in Wales
I measured and cut accurately. Just got distracted with the nice beads I was laying and welded them in the wrong configurationMeasure twice, cut once!![]()
We have the same exact helmetCustom drill modified and corrected. Trial run off bench supply next and then if it looks promising replace 3d printed parts with steel and tidy up.
Siamese twins?We have the same exact helmet
We're both into guns, welding and I'm sure other things too.Siamese twins?
As unassuming as they appear, I know the end product will be far from so.![]()
I'd be curious to see all your machinesA front toolpost to complement the rear tool post I made a few days ago. These will stay on the cut off slide. I still need to make a couple more t nuts and find or make a more appropriate hold down bolt. The cut off slide is very quick acting and nice to use.
Tested the clamps I designed and printed for the level. Trouble with aluminium scaffolding is that it's not magnetic.
Should make lining things up a bit easier single handed.
The redesigned one does. First ones I didn't know how much tolerance to design in as it was the first time printing in PETG so OD of tube is 48.3 so I rounded it up to 49. Worked on the horizontal okay but not on the flat.They look very handy. Im guessing they are robust and clip on positively?
When they eventually fail will you print up a G clamp and another attached at 90 degree to it so you clamp the level to the vertical rather than press a springy clip on them ????The redesigned one does. First ones I didn't know how much tolerance to design in as it was the first time printing in PETG so OD of tube is 48.3 so I rounded it up to 49. Worked on the horizontal okay but not on the flat.
New design just printed at 48.3mm on the inner curve and clips on damn well.
