On the Elegoo site? They're still showing at £300, for me.
Go on, you know you need another one![]()
I got sent an email with a link to their sale. I presume you will get the same as you are an existing customer!On the Elegoo site? They're still showing at £300, for me.
I don't use it as I like the texture. I will, however, have a go tomorrow and let you know!Question regarding the Centauri's. How are you chaps finding using the smooth side of the build plate, (side B)? I tend to find there's a tendency for the print to lift at the front, usually the corner nearest the door hinges. Anyone else noting the same? If I use the textured side of the plate, (side A), no problems with lift.
I'd think it would be alleviated by some spray on 3D printing glue, though?
I started using it with ABS on the Anker and have continued using it on the Carbon. TBH it just works and I've not had any lifting so not sure I'd term it a "hack" as such.Cheers.
I'm not a glue person. I'd prefer to find out what needs tweaking & adjust to suit. Glue has always struck me as a hack.
You do you, though![]()
Yeah - fumes were nasty. My anker was in a flexible enclosure and, of course, the centauri is already enclosed.Any fumes issues using ABS indoors?
Carbon as in Centauri or Bambu?
Hi @MattF I tried today to have a go but my plate type is greyed out?
If you know how to unlock it, I am free all weekend as the Mrs is away![]()
Cool, I had better get one orderedWell, I made an extension section for the nook, to pop it in there, then realised it would fit in there without that extension piece. So, the Centauri has now been moved over to sit with the Jupiter, so I now merely have to find a new location for the Mars.
There's plenty of room for the bed travel.
That print failed. Lifted at the front corner. I've run through levelling & setting the Z offset again, so giving it another try with a large but much shorter duration print.
