Hoses and fittings to hopefully get the bobcat skid steer auxiliary system working again, would highly recommend https://www.parquiponline.com/ great prices and arrived in under 24hrs!
There's more than one way to skin a cat !Temu
Champhering bits finally arrived
So I've had to test them
As well as View attachment 514188cheap Chinese M5 Helicoil set bought because @Kram said that they work fine even if not brand name.
Those were 7 euro only so I've ordered and tested.
And so far he wasn't wrong about.
I've used them on my Stihl cylinder because the muffler kept to loosen up by itself.
The tap is a bit weird feeling but it works at least on aluminum.
The drill bit too it's kinda weird feeling (remember I'm a machinist I might feel better those difference than normal people).
It cuts but feels pretty rigid, it will not allow mistakes for sure, it'll snap for sure.
The inserts worked fine, the tail snapped easily as supposed to, they wound fine, but I've sensed the friction while tightening them up.
Tried both my usual technic and the advised one by Kram and honestly they both work the same.
I think it's just another example of "there are many good ways to do the same thing"
The champhering bits feel a little dull but might be an advantage
Blimey, that's a big lump !Today i have been mostly finding a nice stick of machinable plastic/nylon/hard delrin type stuff..![]()
yea sink is for washing hands coming out of shop plus a perfect height for pizzinBlimey, that's a big lump !
Nice Butler sink tooI've got to make up some similar brackets for one I've got
Useless bits of...![]()
Maybe cause I'm used to high end bitsI've not had any problem with mine. I have two sets. I've dedicated one set to wood & the other to metal.
I will definitely be bearing this in mind when fixing mineplus a perfect height for pizzin![]()
Nice haul of stuff there Memmeddu, bravo,bravoMaybe cause I'm used to high end bits
They worked on aluminum but not on brass
got drawn to the middle death row like a Nassa electro magnet had me
...buried this under the food to get to the tills before the dragon saw it, already have 3 batterys so bare body only and what a great grinder it is, easy switch and does not stall under load with those silly overload cut outs some cheap end have. Ideal to throw in the truck for them get out of a pickle jobs.Top marks for bravery there @roofman !Went to Lidl with the wife for Pasta and a french stick earlier, bolly aze tonightgot drawn to the middle death row like a Nassa electro magnet had me
