I need to acquire two lengths of that, because Im far far to tight to buy it!Today I acquired some pipe, not new but perfectly useable.
Bob
View attachment 498668View attachment 498669
Soup. Brown.They were all in green foil packets (probably still are!), just with different print on them. Biscuits Fruit AB, Biscuits Brown, etc..
Bob
They were.I'm sure they were rectangular plain biscuits and really hard...
Why?
I'm with matt on this. They always look rubbish compared to a nice forged scroll with a tight centre and forged endWhy?
Its great….till it blocks up and overflows down the drive, into the porch! Hence why Im looking for a length of 600 pipe!I've always fancied having a culvert along the front of the house and like a little bridge you drive over with a bit of that big pipe under it. Sort of like a troll bridge...
... Okay you know I've bought it on purpose...Don't go to heavy with it or you'll be replastering as well!![]()
Great! Something else to worry about.![]()
Bit of a traditionalist,appreciate forgework.Why?
I've stopped using a steamer to strip wallpaper at home. It's an old stone house with some less than perfect plaster inside and every time I've used a steamer it has meant some repair work to the plaster!
I use some warm/hot water with a drop of lenor in it. Use a sponge to apply it, let it soak and peel/scrape it off. On washable paper you will remove the vinyl layer first by peeling it.
Once you get onto it it is nearly as quick as a steamer, less messy and no risk of removing plaster.
