DAPPH
as dyslexik as I'm daft
Get a couple of sets of decent blades for it from Screwfix whilst your at it if you can . MY 240 volt multi saw tool was used to slit out grout below the plaster line then drill and break up one tile so I could use the swan neck blade to slip behind other tile and remove them with the least breakage . half a square metre on I was so pleased I'd got two full spare blade sets as the grout & tiles cement ate the gold abrasive cutters and the swan necks .I've been contemplating on weather I need one of these tools, but like you, I now have a job I could use one for. Thanks for the tip mentioning Screwfix, I'll check it out.![]()
If you need reading glasses put them on so you ensure the blades fit over the driving pins before you fully tighten the retaining clamp up (
guess how I found that one out ? ) They are brill for blind cutting into coving to let you slip boards or pipe etc up into the hole you've just accurately cut.
