What a lovely thing to watch! I'd turn the tv off, stick the record player on and fall asleep there.This is one of those logs in the stove.
As you can see, just one of those briquettes fills a decent portion of that firebox.
Is it just me, it looks like a lack of air.
But you have secondary air, so the burn continues farther up, and you are not wasting fuel.Primary air is turned down for that photo. Just running on the secondary/tertiary air there. Easier to see the content without larger flames.
You can usually break them down, into pellets, 3" wide ones, about 3 /4" thick or thicker. For lighting the fire.
I manage to halve what you have there.That method is what I've been using with these for starting the fire. Tried a few minor variations. This one seems to work well.
Three in a triangular configuration at the bottom, with a firelighter inbetween them, & one straddled atop them. Leave the bottom ashpan door open until the flue thermometer reaches a certain point, then close that bottom door & let the integrated airflow systems take over.
Saves faffing around with separate kindling.
Started using the coal box for storing the shorter logs. Breaking up three or so full briquettes fills it.
Haha. I have that bond car somewhere too!Started using the coal box for storing the shorter logs. Breaking up three or so full briquettes fills it.
It's just wood chip under extreme pressure causes it to bind together.what ingredients are in the briquettes ?
Wood chips, and some form of glue/binder ?
