not sure if that's long enough
Magnox cans cut into short lengths, should provide good residual warmth, for a number of years.
That depends on many factors. Split logs dry more quickly than long lengths stacked as they have a bigger surface area. Airflow / wind through the log store. Time of year cut. Also the type of wood, Ash for example, can be burned straight from the tree, silver birch takes years.I wouldnt want the log burner connected to a modern system
I'm currently burning the logs that have been in the log store for 12 months, not sure if that's long enough but they burn nice
Birch is good, if its dry. There are multiple species, one very wet as it grows in really wet ground.Split logs, quite a lot of ash, not really sure on the mix but have seen a bit of birch
Good airflow, and wind, we get ALL the wind
Compressed logs are ok, but proper wood lasts loads longer.
Maybe your stove shuts down better than mine.I seem to be seeing the opposite. Bearing in mind I don't have this stove going all the time, I appear to be going through less briquettes than I did logs. Type of wood log would obviously play a part in working burn time out.
Birch or Sweet Chestnut are common favourites.I have a number of ash trees with dieback. They will need to come down- probably before they fall on something and do damage. What fast ish growing wood can I replace with some of which (not all) I can harvest to burn in future years?
At the moment we are burning a consignment of hardwood. It was from a yacht club jetty that was built on Canvey about 25 years ago at a cost of 80k.
The clubs lease expired & the developers moved in & the club closed down. The redundant launching jetty became a bit of a hazard with kids tombstoning off it. Recently seawall works led to the jetty being demolished & our yacht club managed to blag all the timber. It took 4 large plant trailer loads to move it.
I then salvaged anything usable but 40% ended up as firewood. Terrible really but its all in our wood store now.
Its tropical hardwood, Kapur, keruing & similar, Some of it has gribble & shipworm in it but its been drying for a year so keeping us warm!
Yet another learning day, thanksGribble are a tiny isopod, about the size of a grain of rice, Sort of marine woodlice they burrow into exposed timbers in tidal waters & tunnel just under the surface which breaks away, eventually large sections of timber can be eaten away. Shipworm are a mollusc & much bigger leaving holes up to 8mm dia or bigger in the tropics.
