MattF
- South Yorkshire
How long do you cut normal logs at, about 6" enough?
For selling or using? Whatever length suits your fireplace, if for yourself.
We have just tried them out in our log burner. Easy to light, very hot burning. We burn them with the air gate shut and they still go like the clappers.
Thank you for posting this.As @Barking Mat said, just chips & dust under pressure.
This Youtube video of the machine he makes is a good insight into the process.
Gonna order a pallet of them that'll should see us through 'till Easter I think.
@Pete.: Is it these specific ones you've tried, or a different type/brand?
I'm looking at this stack I have here, thinking that should last me a good while. If it will, however, only time will tell.
Fuel piles generally tend to diminish quicker than one would hope.
Most fires will happily take 9 inches. Our new one above takes 17” max. In theory bigger logs, less time you need to load them. But too big we end up cooking! Too small stacking is a pain.How long do you cut normal logs at, about 6" enough?
Also someone who forgets to feed his cat...You can tell a lot from a man's lounge carpet amd the selection of tools in the house. From yours I can tell you are a sensible single man that hasn't got a wife that insists on fully redecorating and recarpeting the house every other year whether it needs it or not.![]()
Wood burning if you’re buying it, is expensive heating, no matter how you look at it. A luxury living room centre piece.sandwiched between two multi thousand hectare forests but I vouch it is definitely not the winner for efficiency or achievable value, calorifically speaking.
For me it is no luxury, there is no mains gas anywhere within 20km. I rue not installing oil fired years ago when I was having the place renovated. I only used it in the summers back then but I spend entire years here now and burn 14-22M3 a season.Wood burning if you’re buying it, is expensive heating, no matter how you look at it. A luxury living room centre piece.
Oil fired heating isnt bad to run price wise. We are gas free here too and did consider green options, RHI etc. but you can buy a lot of oil for the price differences.For me it is no luxury, there is no mains gas anywhere within 20km. I rue not installing oil fired years ago when I was having the place renovated. I only used it in the summers back then but I spend entire years here now and burn 14-22M3 a season.
My missus used to buy a product called Excel from the coalman, sneaky missus ordered 1/2 ton coal for one bunker and half ton of Excel for the other, she burned coal after dark. The heat from burning the Excel nuggets was notably a lot hotter than a grate full of coal.We burn wood from the farm where it is dumped by the local tree surgeons But I also burn something called HEAT smokeless fuel from the local coal yard. Wood burns quicker and gives more heat but the HEAT will stay in all night and half the next day under a layer of ash.
