I recently did a Mk7 Fiesta and whilst I was expecting similar I was surprised to find that Ford had provided a bolt hole for a lifting etye in exactly the right place. That and the engine crane made the job almost pleasurable!Clutch change on my son's Peugeot 108. Release bearing was getting a bit grumbly and the pedal bite point was very high.
Although this is a small car with a relatively light gearbox it's still an awkward brute to wrestle back up into place on your back on the floor.
I really do need to get a twin post ramp, that and a transmission jack would have made this job so much easier. View attachment 464438View attachment 464439
I've a very heavy 6 speed box to swap in my van. No lift so jacks and axle stands only, not looking forward to it.Clutch change on my son's Peugeot 108. Release bearing was getting a bit grumbly and the pedal bite point was very high.
Think the last clutch I did was years ago on a 1985 Fiat Panda. IIRC I was able to lift the gearbox out by hand, out of the top of the engine bay by grabbing hold of the cable clutch actuator arm.I recently did a Mk7 Fiesta and whilst I was expecting similar I was surprised to find that Ford had provided a bolt hole for a lifting etye in exactly the right place. That and the engine crane made the job almost pleasurable!
R1150GS all back together, quick ride on Saturday and it was picked up same day.
RD250 came in with excessive smoke from exhaust.
Drained oil out of geabox and took exhausts off. Ran it for 10 minutes and smoke cleared up..
Found the smoking gun but technically it is a crankcase split to fit a new seal, a lot of labour.
Said I would try and work a way out to press a modified seal in but no guarantee it will work (got 3 seals on the way).
View attachment 464398View attachment 464399View attachment 464400View attachment 464401
It'll be interesting to know if the biting point is any lower with the new clutch as I thought it was normal on these cars (Peugeot 108, Citroen C1, Toyota Aygo) to have a very high biting point.Clutch change on my son's Peugeot 108. Release bearing was getting a bit grumbly and the pedal bite point was very high.
AHH I thought that was you with it half way out!Looking at the RD it was never fitted right from the off.
It was all going too well. Took it on a test drive on Sunday, all good. Today it's making a rattling / clunking noise in the gearbox area. Had a quick look this morning, nothing obviously amiss or loose that I've had apart externally, guess I'll be taking the gearbox out againClutch change on my son's Peugeot 108. Release bearing was getting a bit grumbly and the pedal bite point was very high.
Grrrr!AHH I thought that was you with it half way out!
A bit like the rear main oil seal on the old Vauxhall Chevette, held in by a raised lip on the block and the main bearing housing turning what should have been a five minute job into the engine out, sump off and crank lifted to replace the seal
Same in the Vauxhall OHC engine fitted to my cars. There was an article on the engine in one of the classic car magazines, and a chap from Vauxhall said that he'd no idea why it was produced like that, as GM group had already produced other engines with a single piece seal. Not only is it a pain because of how much needs to be stripped, it's also a rope seal that has to be somehow cut exactly the correct height above the block and bearing cap so it all fits together when bolted down. And you don't find out it's still leaking until it's all back together and in the car. Fortunately for the OHC there's a two-piece rubber replacement that works quite well - still a pain to swap, but more likely to seal when you do. But no conversion to a single-piece like you get on other stuff.A bit like the rear main oil seal on the old Vauxhall Chevette, held in by a raised lip on the block and the main bearing housing turning what should have been a five minute job into the engine out, sump off and crank lifted to replace the seal
The old 1256cc engine had another bad design fault on the timing cover which had a circular section at the bottom where it connected with the sump, unfortunately it wasn’t deep enough to all the crank sprocket and timing chain to clear the sump when they were replaced. There was also a ridge on the flywheel that meant the ring gear had to be heated more than necessary when fitting, I’m sure that was the cause of premature ring gear wear!Same in the Vauxhall OHC engine fitted to my cars. There was an article on the engine in one of the classic car magazines, and a chap from Vauxhall said that he'd no idea why it was produced like that, as GM group had already produced other engines with a single piece seal. Not only is it a pain because of how much needs to be stripped, it's also a rope seal that has to be somehow cut exactly the correct height above the block and bearing cap so it all fits together when bolted down. And you don't find out it's still leaking until it's all back together and in the car. Fortunately for the OHC there's a two-piece rubber replacement that works quite well - still a pain to swap, but more likely to seal when you do. But no conversion to a single-piece like you get on other stuff.
The old 1256 engine was a design fault itself.The old 1256cc engine had another bad design fault on the timing cover which had a circular section at the bottom where it connected with the sump, unfortunately it wasn’t deep enough to all the crank sprocket and timing chain to clear the sump when they were replaced. There was also a ridge on the flywheel that meant the ring gear had to be heated more than necessary when fitting, I’m sure that was the cause of premature ring gear wear!
